Here's a list of possibilities in order of cause of problem...
WHEN COLD FAST IDLE OUT OF SPEC (norm = 1,000-2,000rpm)
1.) Fast Idle Thermo Valve
2.) Idle Air Control Valve
3.) Idle Adjustment Screw
WHEN WARM RPM TO HIGH
1.) Idle Air Control Valve
2.) Fast Idle Thermo Valve
3.) Power Steering Pressure Switch Signal
Hoses and connections
INSPECTIoN
Fast Idle Thermo valve
1.) Remove the intake from the throttle body
2.) Start engine
3.) Put your finger over the lower port in the throttle body and make sure that there is air flow with the engine cold (engine coolant temp below 85F).
If not then replace the fast thermo idle valve and reset
4.) Start car and hold engine at 3,000 rpm with NO load (tranny in park or netural) ultil the radiator fan comes on, then let idle.
5.) Check that the valve is completely closed. If not, air suction can be felt at the lower port in the throttle body.
----> if any suction is felt check coolant level and for air in the coolant system. If ok then replace the fast thermo idle valve
