TheGSRGuy on Oct/21/06 said:
Why do you want the Spoon ECU so bad?
"because Hector has 3 honda civics with spoon engines..."
sorry i couldn't resist...
anyways... if you want an upgraded ECU (assuming its necessary with your modifications) get a chipped OBD1 ecu and tune it with one of the many quality choices out there such as Crome, Hondata, Uberdata, etc... something that will allow you to run an ecu SPECIFIC to your exact motor build and power goals. no point in grabbing some pre-programmed ecu just because it has JDM Bling factor. Plus... you might end up paying more for something that is by no means better than the others. And be sure you stay away from "spoon chips" on ebay or "spoon chipped" ecu's on ebay... i wouldn't trust those for a second.
