I need to replace my rear sway bar because my stock LS rsb is all rusted out. I dont know wether to go ITR 22mm, 23mm, or the ASR 24mm. I do plan on gettin a sub-frame brace in the "near" future too. Any suggestions?
There's a reason your 24 performed that much better. If you had a 22 and a 23 with no SFB then you added both, you can't attribute all the change to just one of those elements.2LDC2K on Aug/25/09 said:Well hows about an opinion from someone who has had them ALL?
Suspension: PIC Selects 10k/12k (set on full stiff)
Tires: Falken Azenis rt615's 205/50/15
Extra: ASR Subframe reinforcement + Adj. Spherical Enlinks
22mm bar - first upgrade, ran for well over a year with this setup. It was nice, oversteered slightly. hell of a nice upgrade over stock LS swaybar.
23mm bar - second upgrade, ran with this bar for half a season roughly 4 months. Drove a few autoX's with it and road courses and like it but knew instantly almost it was not a big enough change.
24mm ASR bar - Most recent upgrade, been running it for 6 weeks. I have driven the absolute crap out of my car with this bar to find its breaking point as the size made me nervous. Let me just say, contrary to the opinions being expressed this bar is far from over kill. If you have a decently adequate suspension setup then you will love this bar.
Coles Note: 22 bar = decent ; 23mm = unnoticable difference between this and 22 bar ; 24mm = loads of fun
tlangy on Aug/25/09 said:Quote: 2LDC2K on Aug/25/09Well hows about an opinion from someone who has had them ALL?
Also, the OP hasn't specified what type of driving is done. DD? Touge? AutoX? Track? Everyone is going to say something different but if the guy just likes to take the occasional turn hard that's different than if he's at the track every weekend.
offcamber on Dec/31/09 said:Quote: tlangy on Aug/25/09Quote: 2LDC2K on Aug/25/09Well hows about an opinion from someone who has had them ALL? Suspension: PIC Selects 10k/12k (set on full stiff)
nowhere in his post did he say the ASR brace was used only with the 24mm bar. your assumption that the brace made all the difference is just that...an assumption. what does make a difference is bushing material, sway bar size and attachment points.
You don't "see" the difference or you can't tell/feel the difference when you drive?ATegNamedXyla on Dec/31/09 said:Honestly, I don't see much of a difference in anything above 21, but I guess it is really depending on which brand your getting and what your uses are.
BTW Michael Delaney (for us older school members) wrote a whole huge thread on swaybar dynamics and how every 1mm of sway bar increase results in "X%" stiffness. It's full of math and lets you understand what bar best suits your needs.
Me personally, I built my car do go through a corner fast. In doing so I have had to upgrade my RSB 3 times to suit my needs. I may buy the ASR 32mm Hollow bar for raceday purposes as well but we will see. Right now the weak link is my tires so they are gonna be bumped to R-comps!
Hope this helps.
It all depends on your setup now and your driving preference.InnocentAlibi on Aug/24/09 said:I need to replace my rear sway bar because my stock LS rsb is all rusted out. I dont know wether to go ITR 22mm, 23mm, or the ASR 24mm. I do plan on gettin a sub-frame brace in the "near" future too. Any suggestions?
This is what I was referring to in my original post.codenamezero on Dec/31/09 said:Quote: ATegNamedXyla on Dec/31/09Honestly, I don't see much of a difference in anything above 21, but I guess it is really depending on which brand your getting and what your uses are.
Because every mm makes a difference
sgtmillhouse648 on Jan/04/10 said:And the other thing to think about with swaybars is that it's not only the diameter which makes a difference, but also the lengths of the moment arms/where it attaches etc. Look at the ASR 24mm and the Progress 24mm bars for example:
ASR:
Progress 24mm:
Notice how the Progress mounts at the shock mount farther 'out' on the LCA whereas the ASR mounts to the OE sway bar mounting point. This changes what is known as the motion ratio of the swaybar which is the relation between how far the wheels travel up and down to the distance the swaybar tilts up and down. This value ranges anywhere from 0-1. The wheel rate of the sway bar (effective springrate at the wheel) is the spring rate of the bar times the motion ratio squared.
By mounting the bar out at the shock, the motion ratio increases from roughly .55 to .8 IE the progress adds another 36% to the wheel rate opposed to the ASR given design was equivalent (it's not...the progress has shorter 'lever arms' which also increase the effectiveness of the bar).
2LDC2K on Dec/31/09 said:Quote: offcamber on Dec/31/09Quote: tlangy on Aug/25/09Quote: 2LDC2K on Aug/25/09Well hows about an opinion from someone who has had them ALL?Suspension: PIC Selects 10k/12k (set on full stiff) Tires: Falken Azenis rt615's 205/50/15
Wow! Glad someone was paying attention.
What made you think I only had the SRB kit for the 24mm bar? If you check my log you will see I have had the ASR BEFORE I even started upgrading bars. I'm not new to subframe tearout so yea I planned ahead.
As stated what makes the difference is bushing material (oem/hardened PU/spehircal) as well where the attachment points are for suspension geometry and last but not least the size of bar will add to the desired effect.
I laid out my original post as it seemed I am the only one to run the ASR 24mm bar (posting in this thread) and gave the most logical comparison points as the oNLY variable that changed was the size of my RSB. Now all that being said, I still have a 22mm bar that I am going to be doing some heads up testing with in the new season..back to back lapping trials both Solo 1 and Solo 2 and will give an updated review based on my findings.
