Which fuse is for horn?
5.7K views 2 replies 2 participants last post by  white4drTeg
#1 ·
Do you know which fuse is for the horn? I looked in the fuse panel but didnt see anything.
I was installing my horn, and while i was using the ratchet to tighten the screw the power wire for the horn hit the ratchet, i saw a spark and the horn didnt work after that. it worked before i saw the spark
also, now when i went to start the car, the car started but when i went to take the car out of park the shifter button wouldnt push in. It did push in when i put the key in the shift lock release on the shift lever
Discussion starter · #3 ·
yeah i always forget about those fuses, the horn fuse was blown. hopefully that is what is stopping the shifter from moving
EDIT: the fuse is what was causing the shifter from moving, thanks!
