ok i got a wheel alignment the other day, and they told me with my ride being lowered they say they were not supposed to align it to regular oem alignment. so i still have bad camber. is this true? i have camber kits for front and rear. so they can put it to original specs for the alignment. I called another shop and they said the same thing.. "you have to comp for the drop, so the camber wont be exact like as if you hadn't lowered it." which i think is bs because what does a lowered car have anything to do with your tires being crooked and wearing down your tires faster.
what do you guys think?
edit:
does anyone know the factory specs on a 99 integra. this is the alignment report i got from pep boys.
Caster:
left front= 1.30 degrees
right front= 1.12 degrees
camber:
left front= -3.38 degrees
left rear= -1.02 degrees
right front= -3.48 degreees
right rear= -1.64 degrees
toe:
left front= 0 degrees
left rear= -0.03 degrees
right front= 0 degrees
right rear= 0.04 degrees
edit:
Caster:
camber:
toe:
