water in headlights
1.6K views 11 replies 12 participants last post by  integra_guy
#1 ·
my passenger headlight has water in it and is turning the headlight yellow and theres fog in it anyone know what i could do to take it out
#5 ·
forget all taht before i had water in my clear corners.. jus used a hair dryer to dry it out and jus screwed it in tighter if u find a leak use sealent that simple
#8 ·
You put it in the oven to soften up the molding so you can open the headlight and clean the water out. When you reseal it you have to make sure it is actually sealed and water tight
I have to fix my headlight this weekend, still not sure what method I'm going to do, probably going to avoid the oven method for ease
#10 ·
I noticed I got some water in my tail lights too. My trunk carpet area is dry, but under it, where the spare tire is kept, its wet! I think the water dripped through the tailights and into the spare tire area, good thing I dont have an amp there! Anyone know how to fix this leakage? If I brought it to a shop, could they fix it?
#12 ·
GreenGeeSeR96 on Feb/09/06 said:
Yeah, tonight I just took out the bulbs and put a hair dryer up to the holes. It takes a bit, but they do dry out. Hopefully the water will stay out, but if it doesn't, I will probably silicone them. But where do you apply the silicone?
Looks like I'm going to have to do that as well, and drill a small hole on the bottom.
