Originally posted from VP Racing Fuels said:
The four most important properties of racing gasoline...
Listed below are the four basic qualities of fuels. As in everything there are trade-offs. You can't make a racing fuel that has the best of everything, but you can produce one that will give your engine the most power. This is why VP produces different fuel for different applications. The key to getting the best racing gasoline is not neccesarily buying the fuel with the highest octane but getting the one that is best suited to your engine. Octane is the rating of fuel's ability to resist detonation and/or preignition.
OCTANE
is rated in Research Octane Numbers (RoN), Motor Octane Numbers (MoN), and Pump Octane Numbers (R+M/2). Pump Octane numbers are what you see on the yellow decal on the pumps at the gas stations and represents an average of the two. VP uses MoN because this test method is more relevant to racing. Most other companies advertise RoN because it is higher and easier to come by. Don't by fooled by high RoN numbers or an average. MoN's are the most important for a racing application. However, the ability of the fuel to resist preignition is more than just a function of octane.
BURNING SPEED
is the speed at which a fuel releases its energy. In a high speed internal combustion engine there is very little time (real time - not crank rotation) for the fuel to release its energy. Peak cylinder pressure should occur around 20 degrees ATDC. If the fuel is still burning after this, it is not contributing to peak cylinder pressure, which is what the rear wheels see.
ENERGY VALUE
is an expression of the potential energy in the fuel. The energy value is measured in BTU's per pound, not per gallon. This difference is important as the air fuel ratio is in weight not volume. Remember, this is potential energy value of the fuel, and this difference will show up at any compression ratio or engine speed.
COOLING EFFECT
of the fuel is related to the heat of vaporization. The higher thhe heat of vaporization the better its effect on cooling the intake mixture. This is of some benefit in a 4-stroke engine, but can be a big gain in 2-stroke engines.
Quote: Rick O'Donnell
In many high-performance situations, riders clamor for higher octane fuels, thinking this will give them additional horsepower and, thus, an advantage over the competition.
But this is not the case -
adding higher-octane race fuel to your (car or) motorcycle may actually produce less horsepower. Here's why:
Octane, an arbitrary number which is calculated as the average the Research Octane Number (RoN) and the Motor Octane Number (MoN), and is only an indication of a fuel's sensitivity to knock, which is typically pressure-induced self-ignition. (Of these two ratings, MoN is more applicable to racing fuels as it is measured under high load and high speed conditions.)
Octane, as you can see, is not a measure of how much power - or, more correctly, specific energy - is contained in a fuel. And remember that leaded high-octane race fuels burn slower than most unleaded fuels, and may reduce performance in stock or lightly modified (cars or) motorcycles. A high octane rating itself, however, does not (necessarily) mean that the fuel is slow burning. Hence, it has no direct bearing on the power characteristics of the fuel.
The knock tendency (and hence, the Octane rating) of a fuel is a function of the amount of free radicals present in the fuel prior to ignition and can be reduced by the addition of tetra ethyl lead, aromatics and other additives.
Although some racing organizations still use maximum octane number as the discriminating factor for fuel legality, it is really not appropriate for racing purposes.
Instead one should look at the amount of energy (heat) released in the burning of a particular fuel. This is described by the specific energy of the fuel. This quantity describes the amount of power one can obtain from the fuel much more accurately. The specific energy of the fuel is the product of the lower heating value (LHV) of the fuel and molecular weight of air (MW) divided by the air-fuel ratio (AF):
Specific Energy = LHV*MW/AF
For example, for gasoline LHV= 43 MJ/kg and AF=14.6, while for methanol LHV= 21.1 MJ/kg (less "heat" than gasoline) and AF=6.46 (much richer jetting than gasoline). Using the above formula we see that methanol only has a 10% higher specific energy than gasoline! This means that the power increase obtained by running methanol, with no other changes except jetting, is only 10%. Comparing the specific energy of racing and premium pump gas you can see that there is not much, if any, difference. only alcohols (such as methanol or ethanol) have a slightly higher specific energy than racing or pump gas.
Other oxygen-bearing fuels, besides the alcohols and nitromethanes, such as the new EL fuel, will also produce slightly more power once the bike is rejetted.
However, at $15.00 to $20.00 at gallon for the fuel the reportedly minor (1 % - 2%) improvement is hardly worth the cost for the average racer.
The real advantage of racing gasolines comes from the fact that they will tolerate higher compression ratios (due to their higher octane rating) and thus indirectly will produce more power since you can now build an engine with a higher compression ratio. Also, alcohols burn cooler than gasoline, meaning even higher compression ratios are possible with them, for even more power.
The bottom line here is that, in a given engine, a fuel that doesn't knock will produce the same power as most expensive racing gasolines.
However, it sometimes happens that when you use another fuel, the engine suddenly seems to run better. The reasons for this are indirect:
First, the jetting may be more closely matched to the new fuel.
Secondly, the new fuel may improve the volumetric efficiency (that is, the "breathing") of the motor.
This happens as follows: Basically a fuel that quickly evaporates upon contact with the hot cylinder wall and piston crown will create additional pressure inside the cylinder, which will reduce the amount of fresh air/fuel mix taken in. This important-but often overlooked-factor is described by the amount of heat required to vaporize the fuel, described by the 'enthalpy of vaporization' (H), or 'heat of vaporization' of the fuel.
A high value of H will improve engine breathing, but the catch is that it leads to a different operating temperature within the engine. This is most important with two-strokes, which rely on the incoming fuel/air mix to do much of the cooling-even modern water-cooled two-strokes rely on incoming charge to cool the piston. For two-strokes a fuel that vaporizes, drawing a maximum amount of heat from the engine, is essential-the small variations in horsepower produced by different fuels is only of secondary concern.
Also important is the flame speed: Power is maximized the faster the fuel burns because the combustion pressure rises more quickly and can do more useful work on the piston. Flame speed is typically between 35 and 50 cm/sec. This is rather low compared to the speed of sound, at which pressure waves travel, or even the average piston speed. It is important to note that the flame propagation is greatly enhanced by turbulence (as in a motor with a squish band combustion chamber).
The most amazing thing about all this is that you can get the relevant information from mc racing gasoline manufacturers. Then, just look at the specification sheet to see what fuel suits you best: Hot running motors and 2-strokes should use fuels with a value of "H" that improves their cooling, while more power (and more heat) is obtained from fuels with a high specific energy.
By the way, pump gas has specific energies which are no better or worse than most racing gasolines. The power obtained from pump gas is therefore often identical to that of racing fuels, and the only reason to run racing fuels would be detonation problems, or, since racing fuels are often more consistent than pump gas - which racers call "chemical soup."
