I recently replaced my alternator, because my car wasn't charging and it was so bad that it would occasionally die. Well, after I replaced it, it was no better. The ground on the alternator had some corrosion on it, so I replaced it and my car hasn't died since, but it's still not charging.
Immediately after I replaced the terminal, I read 13.8V across the battery terminals while the car was running, but then the problem returned about a week later and now I'm reading 11.8V when the car is running. All I have is a multimeter for testing purposes, so I'm going to take the car to AutoZone in the morning, but is there any other cause that I could look for in the mean time? It seemed for a while that the problem was intermittent, but lately it's pretty constant.
[edit] Also, I should mention, as I don't know if it's related or not. I'm having some ignition problems of some sort. When I'm driving at really low throttle, my car will just completely lose power. It's way worse than a miss, and I'm thinking it could be ECU trouble. If I'm in neutral and I hold the throttle steady with RPMs at about 3000, it will drop down to idle then back up to 3000 repeatedly. I don't see how this could be related, but I've yet to figure out what's causing either problem, so it could be relevant.
Also, the "car charging light circuit test" in the service manual checks out ok, if that's any help.
Thanks.
Thanks.
