How do I remove front bumper on 91 Rs?
7.5K views 1 reply 2 participants last post by  91_LS
#1 ·
The previous owner rear ended something so the front bumper is facing up, causing the lights to face up as well. How do i remove the front bumper so I can fix this? It seems like I have to go through the headlights first but I dont want to do anything wrong and then not be able to drive my car.
#2 ·
You don't need to remove the headlights. Take the blinkers off the bumper and there are 2 bolts behind them.
Steps on removing front bumper on G2 teg.
1.Remover bumper blinkers.
2.remover corner makers (there held on by 1 screw.
3.remove the bracket for the corners. 2 screws on each side.
4. unscrew the 2 screws for the sliders/clips located on each side in front of front tires.
5. remove the 4 bolts holding the bumper on,put something under it to help hold it so it don't drop. The bolts are inside where the bumper lights go,should be 12mm and 2 on each side.
Now under the lip part of the bumper there should be 6 10mm bolts holding the dust cover on,remove and slowly pull the bumper off,you will need to on clip the sides of the bumper from the clips.
7.and you're done,you can now adjust the headlights if needed,but the brackets might need replacing.
