FS: 1999 Integra LS
1.6K views 6 replies 4 participants last post by  adam_seven
#1 ·
For sale is a very clean and beautiful 1999 Acura Integra LS. Asking $5500 o.b.o. It is a 5 speed manual transmission that has had its gear oil changed every 3k miles with mobil 1 gear oil. I change the oil and filter every 3k miles with mobil 1 5w30. It has a new front windshield with lifetime warranty. I have papers for proof. 100% new peak 50/50 antifreeze and new thermostat, also new radiator hoses and heater hoses. Both CV axles are new and have lifetime warranties. Very recently replaced catalytic converter and both oxygen sensors. Tune ups performed every 6 months. New fuel filter, cap, rotor, wires and plugs. I replaced both rear calipers and pads about 3 months ago. Front pads are about 50% worn with new rotors front and rear. I have bleed the brakes to replace most of the fluid with amsoil brake fluid. I have replaced all the clutch brake fluid with amsoil brake fluid. All new royal purple power steering fluid. Timing belt and water pump and belts replaced 1 month ago. Interior is in mint condition. New window motor and window switch. A/C blows cold and heat blows hot. EVERYTHING works. I have receipts for almost everything that I have purchased for this car if buyer is interested. I do all my own work. Honda driveability certified.
Now for the add on's/upgrades
New transmission mount and both torque mounts are new with all motor/transmission mounts having Energy Suspension urathane inserts.
Dual core koyorad radiator with koyorad radiator cap.
DC Sports 4-2-1 header sanded and painted flat black with header paint.
2.25" exhuast with Apexi N1 muffler
AEM under drive pulleys
AEM short ram intake
NGK spark plug wires with NGK iridium's replaced 3k miles ago
40% worn 205/45/16 Yokohama Parada Spec IIs on 16x7 Rota C8's
Blox front and rear camber kits.
Function7 black rear lower control arms and Function7 black rear subframe brace with Energy Suspension sway bar bushings.
Sitting on Skunk2 2.5" lower springs on Tokico 5 way adjustable illuminas
Megan racing subframe "H" brace. No name front upper strut tower brace.
Password JDM magnetic oil and transmission drain plugs with new Honda crush washers
30% ceramic tint around and 50% on windshield with lifetime warranty. Best out there keeps out most heat.
Type R replica front lip.
Paint is 1 1/2 years old.
Skunk2 short shifter and shift knob.
Alpine headunit with infiniti speakers front and rear. 12" MTX audio sub with MTX audio amp in ported box. Rewired car with heavier gauge wire so very little wire is exposed. RCA cables recently broke so they need replacing.
Rear of the hatch has been sprayed with sound deadening material. Yes I have the spare tire.
OEM mud flaps.
I have lost my job and need to move out by the end of september and being able to sell this for a lesser car is my goal.
This car has been started the right way and needs someone to finish my project. She is my baby and is treated as such. only top products used on her and it shows. Cleanest and best running around this area and no strings attached. Title in hand. Any more questions call 770-653-7280
NO TRADES CASH oNLY.
#7 ·
Its saying im kinda certified to work on hondas
i put it on there for buyers not on TI for a little extra "its ok i know what im doing" when people ask what all work i did myself lol
but yeah.... its just a piece of paper i got from taking a automotive course at honda :(
it has 103k on motor and tranny and like 300k on the body
