I have been considering a tranny swap for my RS. I am looking for a little more control in the lower gears for autox and spirited weekend driving but don't want to loose the gearing for highway. The perfect setup would be a 6 speed tranny.
Since that doesn't exist, I have to look at other options. So I have looked at the options available to upgrade or swap my RS/LS tranny.
My options for swapping are ITR or GSR.
I like the ITR's gearing and LSD and it would be perfect if it had a 6th gear. If the ITR tranny had the LS 5th gear there is a pretty big step between 4th and 5th.
The GSR would be to the most part good if it had the LS 5th gear. Since the GSR doesn't have the LSD, it can be added for a fairly high cost.
So this is where the Frankenstein part comes it. Use the ITR tranny and swap in the GSR 4th gear and the LS 5th gear. I am still researching and don't even know if the gears are interchangable between the 3 tranny's.
Here are some charts that I have put together to study.
Acura Integra Frankenstein Transmission - ITR, GSR...
View All (4) Photos in Collection
Before I continue my research, I have a couple of questions:
1) Are the gears between the tranny's interchangable?
2) Am I going way out in left field? If so, please explain.
Thanks.
Thanks.
