Conflicting information about temp guage
1 reading
3.4K views 31 replies 20 participants last post by  fabric8
#1 ·
I've done a LOT of searches and have gotten conflicting messages about what the temperature guage should read as far as normal operating temperature goes.
I bought a used 97LS with 137k miles. My temp guage reads just below a quarter of the guage and never goes past that. I read here that that could be a sign of a bad thermostat.
So yesterday, I drained all my coolant, installed a new 170degree thermostat, flushed the cooling system, then installed fresh coolant and bled the system. But after all that work, my temperature still never gets past the 1st quarter of the guage.
Some threads I've read say that's normal, and others say it should go just below the middle line. Does anyone know for sure the truth to this?
Here's a pic of my temp guage:
#5 ·
This is the post I was referring to. The guage reads just a bit above mine.
I'd hate to buy yet another thermostat if the one I just bought (and the one I replaced) are actually operating properly. They're not stuck open. So before I go and shell out more cash, is there a way to verify if it could be:
a. a bad guage?
b. a bad temperature sending switch?
c. a bad coolant sensor?
What diagnostics can I perform on the system?
#6 ·
If the engine is not heating up and is sitting where your pictures shows, then it's the thermostat. THat's why you should use an OEM honda thermostat. I've heard of people having these problems with autozone...sounds like they open a bit earler and thus the incorrect temp.
It's a 10 dollar piece. Just get a honda one next time.
#7 ·
x2 I used to have a mustang and installed a autozone thermostat thinking that was the problem and it read below what was normal. I also second the slightly below middle for the location the needle needs to be pointing.
#10 ·
If you have your old thermostat still, put it in a pot of boiling water with a thermometer and if it opens when it is suppoosed to, then the issue is not with the thermostat since the needle is in the same place.
Your gauge could simply be miscalibrated. Rare, but I'm sure it happens sometimes. Or a bad temperature sending unit/coolant temp sensor.
#12 ·
I dunno since I just bought mine a couple weeks ago. However, my temp gauge wasn't moving and I replaced the thermostat and it now usually sits between 1/4 and the middle line.
#23 ·
if you call it a "170 degree thermostat", and are using "170" in the right context, then that thermostat you purchased from autozone should be fully opened by 170 degrees. that is way too cold for the car. the factory t-stat shouldn't be fully opened until 194 degrees.
i replaced my t-stat a few years ago, from the carquest i worked at. haven't had a problem with it since.
you can test your t-stat (as mentioned earlier) by hanging it in water (not touching the pot) and bringing the water to a boil. use a candy-type thermometer (not touching the pot bottom) and note the temperatures.
#24 ·
When I was at AutoZone picking it up, the guy at the counter showed me the different t-stat's available. His system showed:
170 degree - OEM range
180 degree
192 degree
195 degree
I belive they are listed in the correct context - the heat point at which they fully open. I went with the 170 degree because it said OEM. IIRC, the Acura Dealer also had similar ranges of t-stat's available - all costing about $15 more than the autozone brand - hence why I went with autozone. If you're saying 170 is too low, perhaps I should have gotten the 192 or 195. Any thoughts?
If I'm going to pull the t-stat again, I'd rather just replace it than test it and have to put it back - especially if the one I got is too cold.
