1991 Acura Integra LS (B18A1)
Automatic Transmission
160k miles
Yesterday my car was cranking but not starting after an otherwise smooth 20 min trip. I was getting a flashing S3 on the dash. Watching the blinking red light on the TCM in the driver side footwell, it did one long flash and 2 short flashes, indicating a code 12 which other threads say is the EGR system. I took a peak and looked to see if my EGR valve is stuck open and it was sticking a bit, but not extremely so that it couldn't move.
I looked everything over once more and then found my 10 amp ECU fuse in the engine bay was blown. In order to get my car home so it wasn't stuck in the parking garage I was in, I swapped the blown fuse for the 10 amp hazard fuse located in the same fuse box. A few minutes after starting my drive home, the check engine light (CEL) turned on and was on the whole way home. I got new 10 amp fuses and replaced the one for the hazard slot, thinking that was what was throwing the CEL.
I drove later that same evening and all was well, but I was noticing some decrease in power and shifting issues, kind of like what others have written here of it being stuck in 3rd gear and not shifting up. About 15 minutes into the drive, my CEL turned on. The car sat for 3 hours before I drove it again, started right up normally, no CEL on startup, still felt like it was having some trouble shifting up and not having a lot of power, and then 10 minutes into the drive, the CEL turned on again.
I disconnected the battery overnight to do an ECU reset and followed the procedure others have suggested of turning it on, letting it idle for 15 minutes to reach operating temp without pressing on the gas, then turning it off and then back on again. It started up fine, no CEL, idled for 15 with no issues and reached normal operating temp and was idling at a little below 1000 rpms, which seemed about right for how it normally idled before this. I decided to take it for a drive on the second startup to see what's what and pretty much immediately when I gave it some gas in drive, the CEL turned on. I returned home and got a paperclip to try and pull the code for the CEL, but with the key in the accessory position and the paperclip inserted, the CEL doesn't flash or anything.
Wondering if this this a code 0 possibly or if I didn't clear the codes correctly? Also wondering what might have caused the fuse to blow. Thanks in advance for any help!
160k miles
