and you thought all that boring high school algebra was a waste of time.
Notice the yellow triangle (that's a triangle that has 1 corner with 90 degrees in it) in a piston, rod, crank as the crank rotates (for us it's counterclockwise).
[Edited: removed the word isosceles.. my mistake - I assumed 2 sides were equal]
Since the maximum load on the crank rod journal, rod bearings, and rod occurs when the crankshaft to rod angle is 90 degrees, we can use pythagorus' thereom and sines and cosines to work out the piston speed at this load and the forces involved.
Anyone want to give a try?
you can also try to calculate the piston speed and forces when the crank to rod angle is not at 90 degrees and no pythagorus here.
just sines and cosines but you need to know the angle or the sides of the triangle which will be difficult.
the rod lengths and strokes for the b18a/b and b18c are on this website.
Remember the crankshaft throw is stroke/2.
good luck
