Problems starting Integra. Details inside
4.8K views 38 replies 14 participants last post by  hpracing007
#1 ·
This is a problem that only comes around during winter (cold/wet months). At the moment the car turns over but does not start. If I let the car sit for a few days and I try again it will fire right up. Here is what I've replaced in the past. Not everything was replaced because of this issue but just general maint.
-Main Relay
-Fuel Filter
-Spark Plugs
-Dist cap & rotor
-Battery
I've unhooked the battery once and hooked it back up and the car started right up.
I don't think it is the immobilizer system because I would imagine that system works or doesn't.
It gets spark, cranks fine, and fuel pump turns on.
Any ideas what to check?
#2 ·
Little bit more information about the car. Miles and other info may contribute to the diagnosis.
I'm still a little fuzzy on whats happening. Will the car always crank but sometimes it won't turn over? Have you checked your starter? If the car is cranking then its not the starter. In which case, are you getting all three things elements of combustion when you try to start the car (oxygen, fuel, and spark)? How is your compression? Do you smell gas when it trys to start? Sorry about all the questions but the problem seems a little vauge.
~Ben
#3 ·
No problem.
It's a 2000 GSR with only about 90k. I've checked spark and it looks good. I also hear the fuel pump turn on but I understand that is not a definite way to know if the engine is getting fuel. The starter is fine and the battery is always charged.
Basically the car will turn over but won't fire. When the car sits for a few days it will run just fine.
Can the distributor slowly go bad?
#4 ·
RuskeR on Dec/05/06 said:
No problem.
Yes I just had this problem.(my car only has 70k miles, first time changed something in the distributor) It was the ignition coil. If you have a multimeter, run an ohms test and check resistance between primary and secondary coil. If not that, maybe a tooth on the flywheel broke off? Did you check your timing belt? Bad ECU signal maybe, and check your grounds also.
#6 ·
Interesting.. I never thought of a bad 02 sensor. Is there any way to test the 02 sensor? I'll check on this as well.
#7 ·
Did you have the same problem? Would the car just not start sometimes than eventually just fix itself?
#9 ·
Almost the EXACT same problem as me. I have a 94 gsr and only recently have i had this problem. one day i got out of class and was in hurry to get somewhere (cuz i was already late) and my car would turn over so i paniced and didnt know what to do. So i just sat in my car and i pressed my alarm (oem) on and off and tried to start again and it started...ionno if that helps but it helped me...could be a coincidence though?
#10 ·
I don't have the OEM alarm but rather an aftermarket one. I've wondered if the aftermarket alarm could be the problem but I wouldn't know where to start with that since I had it installed. :(
#11 ·
Update:
Happened again and I was able to get the car towed to Honda to have it looked over.
Turns out it was the Immobilizer system. Acura told me this system will work or not work.. it's not something that will be intermittent. So I crossed it off my list of possibilities.... but Honda said this was the problem and it can be an intermittent problem. So, a $61 part is all it needed.
I'll update this if for some odd reason that wasn't the problem. Thanks for the advise.. hopefully this thread will help someone in the future.
#12 ·
i have this same exact problem. my cel light is one and it says it's the primary o2 sensor. the only thing is that i have already replaced the catalyic converter and the o2 sensor less than 40k miles ago. What could be causing the 02 sensor to go bad so quickly?
#15 ·
When the car didn't start, did you have a green light shaped like a key that flashed in your gauge cluster?
#17 ·
one time the green key was flashing and wouldn't shut off. This is an obvious reason why I thought it was the immobilizer. I spoke with an Acura tech on the phone and he still didn't think this was the problem because the car would eventually start if I disconnected the battery for a day or so.
#18 ·
tony_2018 on Jan/19/07 said:
could your aftermarket alarm have caused your immobilizer to go bad? that could a possibility someone didn't bypass the immobilizer the proper way.
It's a possibility. I don't know too much about alarms in general so I wouldn't know how to check. I do know that unhooking the alarm from the battery will cause the car to do nothing when you turn the key over.
The main problem was the car would turn over but not fire. Damn immobilizer works so good not even the owner can drive it.
#19 ·
my car is having the exact same problem and i can't figure it out.
It has also been happening on in the cold months. It happened once 2 years ago. I had it towed 90 MILES to the nearest acura dealer (under warrenty) and it fired right up when it got there. They said probably the alarm.
Happened a few weeks ago, so i had it towed to circuit city and they said the alarm does not tie into the factory's immobilizer in any way. I told them to just take it out and make it exactly like stock. Car would not start. We talked about who closer around town could fix it and a friend of his came out and the car fired right up.
If you could find the part number of your paper work like casey said, it'd help me out a bunch! We can't the problem because everytime it goes anywhere a dealer or place to service, it fires right up. Very unpredictable problem that's only happened 4-5 times in 4 years i've had it.
My car had this problem before i owned it as well according to the service records. They replaced the ecu and i suppose that stopped the problem for a while.
#22 ·
Man hope mine is not the Immobilizer system, cause mine does the same thing too. sometimes it would start fine and sometimes it work just crank and not start. But push starting seems to make it work, me i think its my IACV. (MY HAPPENS IN COLD, AND SUMMER) I still don't know.
#23 ·
Yeah, I'll check my paperwork when I get home. Like I said it was only a $61 part.
Have you noticed the green key symbol flashing when your car does not start?
It was also just routine maintenance but I replaced:
fuel filter
dist cap
rotor
plugs
This would oNLY happen during colder wet months.
hpracing007: I hear your pain man. I've had it towed to honda once when it wouldn't start and sure enough when it got there it started just fine. Annoying as ****! Luckily they were really cool about it and didn't charge me but I was out a few hours doing this.
