OBD 1 Sensor in test pipe?
1 reading
779 views 4 replies 4 participants last post by  CtownIntegra
#1 ·
If I drill and tap my O2 sensor in my test pipe and reset my ECU wil i quit throwing the cade for it not being plugged up and will my A/F quit being so rich?
#4 ·
As long as your sensor is good, it needs to be in the path of the exhaust. once your computer begins to read oxygen again the code should reset itself. The zirconia heated oxygen sensor works by comparing ambient oxygen content to exhuast oxygen content creating voltage in the sensor that the ECM reads and adjusts your fuel trim from rich to lean about once every second and a half. It operates in analog voltage less than one volt, but you really need to have it hooked up. Your car will run leaner and you'll get better gas mileage and emissions as a result.
