ball joint question
1 reading
1K views 5 replies 5 participants last post by  pnoygsr
#1 ·
OK, im trying to install my axle. i have ruined my ball joint puller trying to get the ball joint apart, and now ive smashed both my hands, the car is halfway apart, the stores that sell tools are closed, and i need ot be somewhere in 3 hours. how can i get my balljoints apart? i have the fork type guy, but i was told not to use it. im getting ready to dremel the damned thing off, so someone tell me how to do it.
#2 ·
Use the fork, sometimes its the only way.
5 steps to seperate the LCA from the balljoint stud:
Step 1: Take the castle nut and skrew it onto the balljoint threads just enough so that it's sticking of the end of the stud.
Step 2: take a floorjack and jack up on the balljoint stud (the nut is there to protect the threads), compressing the suspension
Step 3: Take the pickle fork, insert it between the joint and the lca (flat side towards boot), locate a BFH and proceed to pound the **** out of it (reminder: you hit the end of the fork to drive it into the joint, not down on it to try and pry it apart). If the fork kinda works it's way towards the dust shield and wedges in there, thats good, it'll direct all the pounding into the joint.
Step 4: dont give up, just keep hitting that f**ker as hard as you can until it seperates, it'll eventually go with a big bang that'll wake up your neighbors, as will your cries of relief.
Step 5: clean up all the grease thats puked out of the boot and squirt some new grease into the boot to replace it.
#5 ·
the fork was missing, so what i ended up doing was getting a HUGE chisle, one that was larger than the space between the ball joint and LCA, and pounted through the space next to the ball joint, forcing it open.
kinda ghetto, but the axle is in, the car works great, and im off to go pick up a chick and get drunk as hell with her, (thats why there was such urgency in my posts)
#6 ·
what i did is, i had somebody hold the rotors up and get the BFH and hammer that b@&th down. dont know how long it will take you but it took me 4-5 hits and it came loose. just my 2 cents. use a floor jcak if you dont have extra hands.
