21 - 30 of 30 Posts
So, this makes me wonder if my ICM is going bad...
It only seems to do it in cold weather, but my tach will be unresponsive until the car warms up, or sometimes it just won't correct itself at all. The problem is intermittent, so it's hard to diagnose. Basically, sometimes in cold weather, my tach is a *****. Do you think its an ICM issue, or possible something in the actual cluster? Could I check this with a MM?
Thanks for the help and great article!
Zack
Discussion starter · #22 ·
b18cFTW on Apr/12/10 said:
i hope someone looks at this reply..but ive been searching and searching until i found this thread but my engine light is on and the code is p1381 which is cylinder position sensor. the car has been in the shop 3 months ago because i was driving and it jus shut off with no warning or light. come to find out it was the distributor so they changed it and exactly a week later it was doing the same thing so they put another distributor on it and its been running fine until a month later the engine light came on one day while driving and it was the crankshaft position sensor. cleared the code and jus a week ago the light came back but now its the cylinder position sensor. the car boggs down at lights and cuts off and starts right back up. im so confused because there brand new distributors and they keep failing.
the car is a 96 integra gsr 5spd
mods: header, catback exhaust, and aem filter. no major mods done
rick
If by brand new do you mean "brand-new-remanufactured" or Brand new OEM Honda (Nec\Tec)??
I have seen remans that cause these problems- I would not cheap out on the distributor.
Was the timing set correctly? This is clearly a distributor issue...
Discussion starter · #23 ·
Zack
I would almost guarantee with 99.89% certainty that it is the ICM- it is what drives the tach- and I strongly doubt the gauge itself is going bad. The problem can be completely intermittent too.
JRutski on Apr/13/10 said:
Quote: b18cFTW on Apr/12/10i hope someone looks at this reply..but ive been searching and searching until i found this thread but my engine light is on and the code is p1381 which is cylinder position sensor. the car has been in the shop 3 months ago because i was driving and it jus shut off with no warning or light. come to find out it was the distributor so they changed it and exactly a week later it was doing the same thing so they put another distributor on it and its been running fine until a month later the engine light came on one day while driving and it was the crankshaft position sensor. cleared the code and jus a week ago the light came back but now its the cylinder position sensor. the car boggs down at lights and cuts off and starts right back up. im so confused because there brand new distributors and they keep failing.
rick
the distributor outside looked brand new im not sure about the housing and all the sensors. i dropped it off at a local shop. trust me i didnt cheap out on the distributor. but im not not sure about the timing either. how would you knoe if the timing is set correctly?
thanks for the reply, rick
Quote: LSDriver98 on Apr/12/10So, this makes me wonder if my ICM is going bad...
Zack
Well then I will be replacing this soon. From a performance standpoint, would I have any power gains from replacing it? Or would I gain some fuel economy?
Thanks again for the help man!
Discussion starter · #26 ·
Doubtful on performance...usually, it either works, or doesn't...whereas things like plugs wear over time.
I have followed this guide and built my own OEM Distributor recently.
Thanks for all the information and might I also add if you are replacing your distributor, you chance the ECT sensor right underneeth it as well. They do work together after all.
Discussion starter · #30 ·
Creating this post as a continuation from the above and limit of 10 attachments per post.
Next is the dust cover. Simple. Just make sure that you get it all the way on so that it reaches the housing. The black wire loom that runs to the ignitor and coil can get in the way.
Lastly, the rotor. This should be straight forward enough...I recommend using Loctite on this one...even though, yes I know there is a lock washer on the screw, I don't know how many times I have seen the screw come off and the rotor grenade into 1,000 pieces.
So I don't know about you, but which distributor looks nicer?? The one on the right??? Don't think so.
21 - 30 of 30 Posts
