Does anyone know where the vent line connects back by the fuel tank? Does it connect to the pump, tank, or fuel filler neck? And does it transition from hard steel line to rubber before the connection? I know the front side runs to the evap can, but I can't find info about the rear connection!
Also, is the vent hose connection a slip joint with clamps, or does it connect with some special hose or fitting?
FUEL LINES
I've pretty much decided to go with nylon braided 6AN hose and AN fittings and transitions (to NPT). I'm going to do away with the stock tank fuel feed line, the one with the banjo bolts, and run the line directly from the pump to the bottom side of the stock fuel filter in the engine bay. I'm spending a lil extra for the black nylon braid because the whole problem is rust, and I don't wanna re-do the lines if the stainless steel braid rust out in the future. I considered running them through the cabin, under console and carpet, but id rather just keep it outside and go with the nylon. Plus I don't have to drill holes for a bulkhead, or buy the bulkheads.
I'm stopping at the stock filter for now. Everyone memes that the stock fuel system is good for about 500hp, or something like 30lbs of boost (idk), so I'm leaving the stock rail, injectors, and pressure reg in place. I might make a drop hose from filter to fpr, we'll see how it goes.
I'm gonna use 4AN hose, also nylon braided, for the return line.
If I re-run the vent line to the evap, I'm gonna us 4AN for it also. Idk though... hose at $4.50/ft and fittings at $4 and up... I might come up with some other solutuon.
BRAKE LINES
I'm still planning to go with pre-bent oe lines for the rear brakes. I don't like the idea of replacing it wih more steel that'll rust again, but I don't have any other options to speak of... besides running them through the cabin, which hasn't been ruled out yet!... and may be easier than dropping the rear suspension and all to fit oe lines.
I was also planning to buy a POR-15 kit to touh up the underside, so another option is to try painting the new lines with that stuff before I put them on. Idk... just a thought
Although the odds are that the new lines will outlast the car, so maybe I'm worried about it too much! LOL
