AEM Big Brakes Compatible with Wilwood?
1 reading
1.3K views 5 replies 5 participants last post by  GunNam
#1 ·
I have a AEM Big Brake kit in the back w/stock calipers. I want to upgrade to Wilwood Calipers. Will they work with the AEM kit?
#3 ·
Good question have you contacted Wildwood or AEM and asked them. They most likely will tell you to size them up and see if they rub against the wheel. Or AEM sells the 4piston calipers for there Big Rotors. Try them and see what happens. They should fit as long as the brackets are compatible with the calipers themselves. Good Luck.
