I was just sitting at home today, debating if it was the day to actually attempt to rebuild my transmission or not. Well, my curiousity and my love of all things mechanical led me to crack open the case of my broken transmission. I took a few pictures to share with everyone here.
Should you be afraid? Let's me realistic. Everyone says that a transmission is oh so hard to work on. Really now, is it? Let's take a look at the basic makings of a transmission that's been torn apart. Provided you have a Helms manual, some common tools and a set of feeler gauges, transmission repairs and installations for LSD's can be done at home. We're going to overcome this intimidation of the unknown and learn to do this ourselves. f**k being raped by the transmission shops.
First of all, let's take a good look at what the transmission looks like with the case opened up.
We'll take a little closer look here. Check out the size of that differential compared to the rest of the gears...
And yet another view...
Here's the two "towers" of the transmission, the one on the right is the main shaft and the one on the left is the countershaft. Then, we're got the three shift forks...
A slightly closer view of the shift forks...
The shift assembly. This is where the three forks hook up to the link...
A closer view of the shift selector...
Ok, here's the money shot. Really important stuff. If you look at the bottom of the three shift forks, you'll see that there's three little notches that are lined up next to each other. You'll see that there's a little link that runs through all three of them. When you rotate the gearshift from left to right, it goes back and forth between those three links. When you push it up into gear, or pull back down into gear, it either slides the shift fork up or down, pushing the synchro into the gear selected...
Here's a closer shot of that same assembly I was talking about. Note that the piece that goes through all three links has a notch in the middle. That's the actual notch that lines up with one fork or another when it rotates back and forth, and once it lines up with one, it can push it up or down, depending on which gear you select...
Here's a closeup of the fork to select 1st and 2nd gear hooked up to the synchro hub. You can see that if that hub slides up or down, it will push the hub into the gear in question and it will be locked up.
Here, we go to the other side of the towers. If you look at the bottom, there's a little gear that's just sitting freely, independent of the other two shafts. That, my friends, is your reverse idler gear. When you select reverse, it hooks that gear up to the shafts and puts the car into reverse. Also note that the gears are ALWAYS intermeshed. You literally cannot grind your gears. You're grinding synchros. You can all throw away the myth that short shifters can damage your transmission by causing grinds. When you throw that shifter, it's the limited movement of the synchro that stops the shifter from continuing it's travel, not the length of the shifter. Everytime you put it in gear, the synchro is fully locked in...
In the picture above, all the brass colored rings on the main shaft and counter shaft are the synchros. Anyways, here's another view of the reverse idler gear. Note the black fork that's hooked up to it on the left side. That's what actually moves the gear in or out, depending on whether it's up or down. (Which explains why reverse is always so difficult to put into gear...)
Tucked in at the bottom of our countershaft is our final drive. See how it hooks up to the differential?
All this really wasn't that complicated if you get yourself a copy of the Helms manual. Here's the pages that teach you how to crack open the case to the tranny. This book even teaches you to check tolerances and specs and how to take apart the rest of the tranny. There's a total of 110 parts, and every single one of them is listed in the Helms.
When I have money, I'll complete this with a lesson on how to rebuild the transmission and put in an LSD at the same time.
