1 - 15 of 15 Posts
well...my cousin was boostin last week with 140k miles...drag3 turbo kit...intank fuel pump...FMU, FPR, and inline fuel pump...We took the kit off because he neeeded to sell it...did a compression test..his is an LS with 140k miles
compression results were..
145 135 150 70
lesson learned..: change your headgasket.. ;-)
Deadlock is boosting on 140k I believe...no problems...boost is not what kills an engine...bad or no tuning is what kills it...
do a compression check
yea 145k+ miles I'll be doing a compression test soon, I was at 185 accross before the turbo.
tuned at 8psi
g2iguy on Apr/22/04 said:
would it be safe for me to run a greddy turbo with 85k miles on the engine and chassis?
yea, like Justin said, boost is not what kills the engine, its bad tuning.
if you use the greddy blue box or the new e-manage you will be fine and safe.
tuned at 8psi
Before anyone asks, 180 on all cylinders is great for a b18b with those miles...even better with a turbo on it for the last 10k. (I believe that's how long you said you've had it boosted)
i was at 215 210 215 215 before and after about 500 miles turbo. but the motor has around 70k miles on it
Thanks Justin, yea if you keep it in good condition, it should be fine.
I'm the second owner of the car, it had 133k on the clock when I got her in 2k2.
and before anyone asks why does Brent have 210 range and mine are so much lower (185), its a b18b1 (LS) compared to b18c1 (gsr)
the gsr has higher compression. i also belive that the previous owner put a thinner head gasket on as well. my comp numbers seem a bit high.
In my experience, the engine holds up better than the tranny.
I have REV hard t3 t4 precision turbo and just did my compression test
210 195 190 200
i think the turbo has be on for 10K. I have an integra LS motor. baby still holding strong. This is with FMU at 6 PSI
1 - 15 of 15 Posts
