Rudy..I dont know a whole lot about F-Max but I would assume that since it is a kit it will come with almost everything that you need. I have a Rev-Hard stage 2c kit and this is what it came with so you can use this list to check against what your F-Max kits comes with..
Rev Hard T3/T04E Turbo
Rev Hard Intercooler
Cast Iron Manifold
Deltagate Wastegate
Vortec Blow Off Valve
2.5" Aluminum Charge Pipe
2.5" Downpipe
2.25" Aluminzed Mandrel Bent Piping
Progressive Type Fuel Regulator
MSD Inline Fuel Pump
Purosil Hoses & Clamps
Steel Braided -3 Oil Line
Oil Return Line
High Pressure Fuel Line
High Pressure Silicon Hose
Neccessary Vacuum Tee's
Neccessary Vacuum Lines
The extra things you need would be guages, a pilar or bezel to hold the guages, some type of fuel/engine managenment ( I use a Apexi VAFC right now), and a larger diameter exhaust. Also make sure you have all you regular maintenance up to date..like good gaskets, new timing belt and water pump, valve adjustment if necessary..stuff like that.
Optional upgrades might be larger injectors, aftermarket ignition, electronic boost controller, Hondata or AEM EMS, upgraded wastegate, new oil pump, new radiator, aftermarket electric engine fans, etc. etc.
I'm sure if I missed something here someone will chime in and add to my list.
