Yea actually I think Acura recommends that the timing belt/water pump should be changed at 60k. I believe they also did a coolant flush (didnt charge extra) for that. They *should*, at 60k (90k similar type of service, as Acura breaks it down into the "major" ones at 30,60,90, etc.) replace plugs, wires, distributor cap and rotor, flush brake fluid, tranny fluid, power steering (if applicable), oil change, fuel filter replacement, air filter (they actually cleaned out my AEM cai free with the Aem recharger kit that I have), and obviously change the oil, filter, and washer while their at it (many places neglect to do that last part). I would recommend that since they are looking at it, might as well ask them to check the underbody for any loose parts (for instance sometimes around 60k or so the heat shield near the cat coverter has been known to come loose and make a rattling noise), and I personally replaced my O2 sensors at 60k (though there wasnt anything wrong with them). And as mentioned I believe, they should also check the the condition of belts for any fray or wear or such, and the mechanic usually takes the vehicle for a test drive to test alignment and balance of the wheels (you'll notice a vibration in the steering wheel around highway speeds if your wheels are unbalanced). That's all I can think of off the top of my head for now. =O).
