1 - 9 of 9 Posts
I looked in both the 94-97 and 98-01 service manuals and that harness normally has four connectors: Parking/turn signal light, side marker light, front window washer motor, and rear window washer motor. None of these have a green with white stripe wire.
Can you follow the harness to see where that wire comes from? That may give you an idea of what it is there for.
Discussion Starter #4
Thanks for putting time in to and I followed it back it goes to the cab and we'll itsee lost after that and yeah the guy that had this car really screwed it up
I was just in there doing a tuck on mine and I know this wire but don't remember. I can check later today after work and get back to you. I want to say its to one of the headlights. I know one is green with red stripe....
It should be for the turn signal / side marker. It's the outer, small bulb.
Green/White - Side marker (small bulb)
Black - Ground
Red/Black - Parking Lights (large bulb)
Green - Turn Signal (large bulb)
If I were you, I'd go to a junk yard and get that part of the harness off a wrecked integra and redo it. Use solder and heatshrink instead of those butt connectors.
1 - 9 of 9 Posts
