Hello, I recently joined this forum as well as I recently bought a 1998 Integra Gs. After finding some oil leaks and some other minor issues, I discovered this connector touching my alternator belt, eating the belt and wires away (I moved it out of the way). I can’t seem to find a female connector for this plug, anything helps, thanks..
105608
Could be crankshaft position sensor
If so, it plugs in at the very bottom of the block like under the timing belt and it’s a magnetisms only pugs in one way.. I normally have more of a issue with It trying to touch the timing belt... if I’m right if not I’m not sure what it is. But there is supposed to be a bracket holding a few wires on top of the alternator
Okay cool, I’ll check it out here in a bit. My check engine light is on for emissions and vehicle speed sensor on the transmission. Purchased a new sensor and will be flushing the trans with new fluid. From the looks of it i have to get a new connector piece and plug it into wherever it’s suppose to go.
