1 - 20 of 36 Posts
i'd stay with a darker color such as bronze, steel grey or gunmetal. I don't like blacks because most of the time it looks like they are just steelies.
i narrow my colors to \
1.bronze
2.gunmetal
3.steel grey
also how much lighter are the rota slipstreams compared to the 2000 gsr blades,im planning to sell blades when i do buy slipstreams, what are the lightest tires to go with the slipstreams
pick the color YOU like best, YOU have to live with them
as far as a light tire... the yoko avs es 100 is pretty light
one more question
PCD/Offset: 4x100+40mm
PCD/Offset: 4x100+45mm
PCD/Offset: 4x114.3+40mm
which one of these is the offset for 2000 integra
Weight of the tire has a GREATER effect than weight of the wheel. Further distance away from the hub. So why doesn't it matter? Toyo T1-S is about the lightest street tire out there. With that said, get a tire based on how it grips/handles/wears in the conditions you're driving in, then worry about weight.
They make the Slipstreams in 15" x 7" now, I have a set for my race tires. I have bronze and like them a lot, but then again I'm a bronze fanatic. I think almost any color would look nice, but that new gunmetal with polished lip is very nice too - was going to get that but it wasn't in stock when I needed them. But I think for dark green you should not get a shade of gray, but definitely a bronze. 15" x 6.5" = 11.9lbs, 15" x 7" = 13.0lbs.
royal steel w/polished lip... 16"
EDIT: If you go 7" wide i wouldnt recommend anything under 45mm for the offset.... 45 is perfect on 16x7 with 205/45/16s...
Id say for a green teg to go for the bronze slips, the two colors just compliment eachother
anybody know the wheel offset for the 2000 integra and is this a good price for the slipstreams
Home > - Rota Racing Wheels > ROTA Wheels - Slipstream (16x7)
Availability: Usually ships in 2-3 business days.
ROTA-SLIPSTREAM-16X7Retail Price: $180.00Sale Price: $124.95
Color: SilverWhiteBlackBronzeSteel Grey
Pattern/Offset: 4x100+40mm4x100+45mm4x114.3+40mm5x114.3+40mm5x114.3+45mm Quantity:
right now im dropped with neuspeed race springs and koni yellows, so what offset do you guys recommend,40 or 45 mm
i figure for gen 2 tegs the patter is 4x100
1 - 20 of 36 Posts
