I've recently got mi self a 1995 integra. It has a non vtec b20. It drives perfectly but i have this wierd stifnes every time i change gears. The gears dont crunch and are completely smooth.what is it thatis making mi shifter feal so sif when i shift?
You'll probably want to get under the vehicle and check where the shifter bolts to the shift linkage. A lot of people do not install the proper bearings, and end up over tightening this bolt causing a stiff shift.
Thanks man, ill see if does any thing.
