1 - 2 of 2 Posts
My integra makes a knocking noise when I give it gas its scaring me what do i do and what can it be? Its no like a constant knock it does it at different rpms.
Engine knocking is usually do to low oil so check your oil level first. If your oil level is ok then check compressions in your cylinders. If compression check ok the check for engine valve lash and set to recommended specs.
1 - 2 of 2 Posts
