Well, I got the estimate today for the water damage to my car and it is $7875.00! So... I'm going to see if I can get the insurance to just give me a check for that amount and do the work myself. With the money I'll save in labor I will be able to add a whole lot of goodies to it. Here is the plan:
New Block - Required
JDM ITR Pistons
ITR Rods
Jun Cams and valve train
JDM ITR Tranny
New Clutch and Flywheel
New Fuel System
AEM P&P ECU
Plus all the gaskets, and required fluids/parts damaged by the water.
Suggestions welcome as to other things needed or recommended. The insurance money won't cover everything, so I will have to add some of my own money, but that's not a big deal. I'd like to add a skunk2 IM to that along with some other stuff, but I am mostly trying to focus on things that need to be installed while the engine is pulled and ripped apart. TIA
David
Low compression head gasket
full gasket/seal set
Polished GSR crank
Crower steel billet rods
JE rings and pins
JE Forged 9.8:1CR pistons
Sleeved and girdled B18C1 block
Skunk2 cams, retainers, springs, etc.
AEM fuel system
Upgrade head bolts
JGEdelbrock IM w/ BBK TB
Custom T3/T4 hybrid turbo
Hondata equipped ECU
Polished GSR crank
Ported and Polished B18C1 head
Stage II racing clutch
Civic Si or Integ LS tranny with Quaiff LSD
Nozzle lights
Just another option for you.
From what I've seen JE makes N/A pistons and rods as well. I'm just not a big fan of JDM stuff I guess. They are worth looking into.
