I have turbocharged my integra and finally got it running. When I get on it, I hold boost well with no leak. My external wastegate has an 8.7 psi spring, but the boost gauge only reads a little over 7 psi.
My wastegate vacuum line is hooked up directly to the turbo. I am guessing that the wastegate is reading 8.7 psi from the turbo, but once it goes through my piping and intercooler, it goes down to 7 psi. Is this my problem?
Should I take the vacuum line around to the intake manifold? I dont want to hook up a boost controller, because I can get trigger happy and turn it up too much.
