I bought a Turbonetics wastegate (yea i know but it was cheap!)
There a 90degree fitting near the buttom , i think it goes to the turbo housing via vacuum line.
Then theres a Threaded hole near the VERY TOP of the wastegate.
What do i do with this hole?
Plug it?
Buy some fitting and run it to where?
Leave it ?
Any help will be appreciated
Please chime in anyone Thank you.
Cant wait to booost my Integra
depends on what boost controler you are using
a) no boost controller... leave it alone
b) manual boost controller... leave it alone
c) electronic boost controller.... connect it as per the controller's instruction
^^Exactly. The top port is left alone unless you are utilizing an electronic boost controller that uses feedback. Electronic boost controllers use that top port to more precisely control the wastegate opening/closing. So if you don't have one, just leave it and DoN'T plug it.
Thank you guys for your help and fast replies .
i have a manual boost controller
"Just a few more things and the turbo is goin in" .
.....I must have said that a hundred times.
Thank you guys
