1 - 10 of 10 Posts
w00t w00t... just bought a used USDM ITR cluster... pretty clean with bout 16k miles on the odo... for $120!!!! i hope it was a good buy.
Anywase my question was.. does any1 else have problem with the electrical lights being on? or off? dont know the year of the ITR it came off from, but it went into my 94 RS and the door light wont go off unless i buckle up, and the seat belt light dont even come on at all. Any has this bug too?
hold on. there is seat belt light? where the hell is dat at? or is dat in the obd2 vehicles? i gota obd1 95.. LS/SE cluster.. belt light.. see nwo thats freaking me out lol
LMFAO seat belt lights are on all cluster..
and how is this off topic? im specifically asking a question bout a problem for G3 tegs...
the reason i bought it was coz mine wasnt working right.. and i was gonna spend the money on just getting a GSR cluster.. but then found an ITR one for bout the same price.. so i got it.. and eventually.. i will be able to rev higher than just 8.4k RPM
I found this post in an old thread
TeggyLS on Dec/19/03 said:
i had a early ls cluster maybe 94, 95 or something in my 2000 for a day and:
the srs and seatbelt icons were switched, the abs stayed lit, the maint. re'q light turned on after the ign. was off and stayed on, the fuel and temp shot to the right when i turned it on and remained there till i turned the car off, and when i engaged the blinkers the rpm and mph needles flucuated down-down-up-down-up until i turned them off
something to think about
*EDIT*
Here is the thread I got that from. Sounds like the same situation you have. The last post has the fix for you.
i just bought an ITR cluster today in place of my LS cluster. I switched everything that needed to be switched : green film, and the ABS, Seatbelt films, etc... everything works fine, only thing wrong is the door light never turns off and my spedometer is not working correctly. i have a jdm gsr tranny, and at 4000rpm it should be at 80 mph, but instead its only at 58mph or so, does anybody know what the problem is? any help is appreciated, thanks.
1 - 10 of 10 Posts
