Logic0010...yeah i have tried two different ECUs and two different solenoids, no luck so far.
TheGSRGuy...thanks for the link, ill read that over, maybe it will help out.
GunNam...Yes i am using the JDM ECU. What do you mean JDM spool valve/vtec solenoid?
The set up is 98+ spec JDM ITR motor with 99 USDM GSR wireharness plugging into 99+ spec ECU. Like i said before we have swapped out JDM ECUs and solenoids and no luck yet. My brother talked to two shops that he knows and they both said something about using a "wire harness adapter" like this one...
http://www.boomslang.us/obd2to1.htm
does anybody have experience with using this adapter or one like it, and do you think this might help me with my problem? Also which of those wire harness adapters would i use with the 99 UDSM GSR harness and a 99+ spec JDM ITR ECU. Also i have a VAFC 2 i will be installing on the car once the fuel cut problem is fixed. The link i posted above, they also sell plug and play harnesses for the VAFC. I just wanted to see if anybody has used these harnesses yet...
http://www.boomslang.us/vafc2.htm
If you guys can let me know if you think those harnesses might help me out with the problem? Also let me know if any of you guys have used them before, thanks.
