ok heres the deal
i just replaced my alternator i saw the kats at napa test it...it worked fine
brand new alternator..new battery and my battery is still runnin at about 12.4 volts when it should be runnin at around 13.98 volts witht the alternator running...we checked all our major grounds stereo wiring cleaned our major wires connections...and still it isnt charging
any ideas what could be happening
This is a long shot...
Assuming all wire connections are good, there's a chance that your belts are slipping a bit. Like I said though, that's a long shot, I'm still imagining a wiring problem, or...
How is everything electrical functioning right now? I know my friend fried a couple of alternators when installing a new one by accidentally hitting the alternator w/the wratchet when it wasn't grounded.
if you remove the main system fuse at the battery (hopefully you have one!) and check the voltage at the battery
if you get the right voltage (over 13.5 volts), then you are ok
if you get 12-ish volts, something else is wrong (not your system)
just helping you by telling you how to figure out what it isn't
electrical problems are best diagnosed by working backwards.... eliminate the eliminate-ables
taking your system our of line by killing all power going to it should be your absolute first step....
and if your car is running and you dont show 13.5+ (should be in the 14's actually) on a voltmeter, then something is wrong with your charging system...you'll be wasting your time guessing at other stuff until you get that straight
