I'm planning on buying a VIS OEM carbon fiber hood. Im just wondering what else i'm gonna need for it. I've looked through the forums and everyone is talkin about weather stripping. i know for sure im gonna buy the rubber Where can i get it? is there anything else i'll need to get?
i know for sure im gonna need to get me the rubber thing in the front (#9) do i really need to get all those screws?? (#26) it says i'd need 16 of em. i'd appreciate any help i can get.
i'm pretty sure all you need to do is switch the front rubber gasget to the cf hood
and #26 isn't screws... they're just plastic rivets. you should just be able to use the ones from your stock hood provided you don't mess em up too much when you remove them.
well i was gonna use the one on my stock hood but im planning on using the stock hood when winter comes. so is that rubber thing the only weather stripping thing i need?
yea thats about all u need. u can just use the rubber strippin off the stock hood, then when winter comes, take that off and put it back on the stock hood.
Unless you drill holes in your vis hood you wont be able to use the plastic rivits. I just used some 5-min epoxy and it turned out great.
