Hey all..
Just tried spraying the passenger side back fixed glass door moulding. Anyway I used vinyl paint cause I thought it'd hold better - be more flexible..
It looks good, except now its dried it sort of has this "spotted" effect .. like that when you spray paint something, but then it normally dries and is smooth and flat. Its very slightly rough .. but looks like 'spotted'.
BTW I wet-sanded the moulding and took off all the oxidation and crap using 1200grit wet/dry paper ... then sprayed about 4 coats of vinyl paint.
Should I spray a layer of normal paint now?? so, if it cracks, the vinyl paint is underneath?
It just looks a bit strange being that spotted effect..and slightly rough
mine looks spotted too, even with the adhesion promoter.
