Teg: 2000 LS 2DR Auto, 69 K miles.
My valve cover gasket leaks at the front. The so called cam seal appears to be fairly clean. In lieu of replacing the gasket with a new one, could I effectively stop the oil leak with a slight tightening of the valve cover bolts at the front ? I'm afraid if I torque too much, the oil leak will be worse. Any suggestions ? What is the max. torque for these bolts ?
