Specific answers:
There will be a slight vacuum in the intake manifold even at WOT. If there was no pressure differential there would be no flow.
Then I assume AEBS engine just has a standard open system venting excess blowby to atmosphere through the two valve cover openings. I assumed since the two openings are threaded that they hooked up to a catch can. If there is no manifold connection, the catch can would only would only be used to catch any excess oil and prevent it from getting on the track. The catch cans on most race cars are only that, catch cans. I don't know of many race systems that have a connection to the intake manifold, so the catch can can't function as a liquid/vapor separator as it does in a street application. A race system plumbed into the exhaust system might use a catch can as a separator.
only in a system that always maintains a crankcase vacuum would the crankcase filters always have air going through them one way. It depends on what type of system is being used. Since there are also different types of race systems,you will have to specify exactly what type of system you are referring to.
Your turn
Your turn
