How are these bolts called! The ones that holds the valvecover and Sparkplug cover, i broke 2 of them, on top, so the sparkplug cover cannot be bolted on 2 bolts!
Please help me out with part# , name of part, and what effect does it have to keep driving with 2 bolts of the sparklug cover loose?
later
there called acorn nuts, there pretty pricey from acura.
As long as it's just the plug wire cover it's fine. If it's a bolt directly contacting the valve cover then you may have leaks. Make sure if you are ever tightening any bolts on the valve cover again to use a torque wrench as they break very easy. 7.2 lbs-ft is all they are supposed to be tightened down to.
well till now there not leaking.Well the thing is also I have to take the sparkplug wire cover of to see If the 2 on the left side are leaking.Is there a possibility that the valve cover will leak with these 2 bolts broken?
The rest are fine!
