1 - 2 of 2 Posts
If my upper radiator hose doesn't get hot, does that mean that my thermostat is messed?
And by the way, what is the thermostat for?
yeah, if your hose isn't getting hot your not getting flow. either a problem with the water pump or more likely your thermostat. the thermostat is actually located where the lower hose comes out of the motor and when it heats up it opens up the path for coolant to flow through the motor.
1 - 2 of 2 Posts
