1 - 20 of 694 Posts
Links to Updates:
Page 2: Mounting the Fuse box and Rerouting the Passenger side Wiring harness through the fender
Page 5: Mounting passenger side wiring harness to fender well and giving my Hid's a new home
Page 6: Starting on the driver side wiring harness and removed the wiper motor
Page 8: Parts I have Sitting in my house waiting to be installed & Rerouting my driver side wiring
Page 10: ABS Removal
Page 11: Prop Valve, GE manifold, and Bulkhead mounting
Page 13: Relocation of the Prop Valve
Page 14: SS Caliper Brake line install
Page 15: Building Brake lines and test fitment
Page 16: Finishing up the 4th line for prop valve in the bay
Page 17: The rest of the motor removed from the engine bay
Page 19: Starting on Body, Brake booster Removal
Page 22-23: Welding, brake lines, motor, ecttttt
Page 24: More welding and putting my motor back together
Page 25: More welding/grinding and positioning the circular connectors
Page 26: I Bought Filler Products, Ready to apply filler
Page 27: Filler Time
Page 28: Filler, Removal of Subframe and front suspension, New Rubberized undercoat
Page 29: New bracket Welded, Valve Cover Cut
Page 30: Bay Primered, Ready for Paint
Page 31: Bay Painted, CLEAR COAT
Page 32: More Clear Coat Pics
Page 33: Starting on the Wiring
Page 34: Circular Connectors soldered
Page 35: Reinstalling Time, Fender Wells, More wiring
Page 36: NEW PARTS and Powder Coated Parts
Page 37: Passwordjdm fender washers/bolts, More Installed in the bay, Brake/Fuel lines made
Page 38: Passwordjdm fender washers/bolts installed, More Installed in the bay, Brake/Fuel lines made and installed
Ive been working on my wire tuck for the last week or so.... Ive made some progress so far.
First off, i went ahead and took the head off because i knew with that off, id have plenty of room to work around in the engine bay without taking out the whole motor. Ill eventually pull it but not yet. Another reason i pulled the head was cuz i bought a new one :)
Along with taking the head off, i went ahead and removed the radiator, bumper, fender, all my intercooler piping and intercooler. I had already removed all my ac crap and ps crap on my last motor build. Then went ahead and took out my stupid emissions crap(i know the car wont pass emissions w/o it, and i dont care). I went ahead and removed my windsheild washer fluid bottle and all the lines that went with it. ok i think you all get the point :)
Then i went ahead and removed my Dashboard. That people is a BIG pain in the behind.
While the dash was out, i went ahead and threw away my heater core and AC blower box. Heavy peices of JUNKS :)
My plans are to go with a FULL wire tuck, not this half ass tuck. I mean relocate the battery and fuse box. Remove my ABS. Relocate all my brake lines to the inside the cabin. Weld all the holes shut. Repaint the engine bay. Pretty much have my engine Floating :)
Here is the pictures of how it was 2 weeks ago:
and here is what my car kinda looks like now but W/O the Window sticker now!
Thanks man. Im hoping to repaint the whole car while doin the engine bay :) But hopefully that will be apart of the this progress thread!!!! Give me a few minutes and ill post up some pics of how my progress is going as of now....
Heres my bay as of right now:
Driver Side still untouched:
No more Battery, Fuse Box or Wires along the Pass side:
Front Bumper Gone :):
Pass side Fender Removed so I can start this side of the Tuck:
Here is where all my wires lie, Can you see that Fuse Box? It will soon be resoldered and mounted in its new location:
And finally, all those ugly heavy boxes are gone! Now to mount my 99-00 Civic SI 40/40 prop valve in that general location:
plans on the ground wire?
I cant figure out a good spot.
The one that attaches to the valve cover from the radiator support.
Well, some people move it to the right rear of the Valve cover and bolt it up to the lower part of the frame. But then again, i hear that you can remove that ground wire. Ive ran without that ground wire before and i didnt notice any problems, but then again Im just gonna mount my to the location i mentioned above. Make sense?
Ill look there and see what I can do. Thanks
and good luck with the project.
OK so this is where i stand on my project! It took me a couple hours to do 18 wires for the fuse box cuz i wanted to make sure i got it all right and make sure no wire were showing. I dont want to blow fuses :( I put shrink wrap on it AND wrapped it with electrical tape, Can never be TOO careful ;)
Here is the Fuse box, CUT and ready to be soldered:
Here it is all soldered and Wrapped up:
A closer look:
Discussion Starter · #15 ·
krayzielilsmoki on Jun/01/07 said:
This is what I want to do, make sure you take pictures every step of the process because I am using this as a reference
haha, i was just reading your build on your motor! hows it coming along?? sorry but 55 pages is a lot to read so i was just looking at pictures and skimming through some of what you wrote in the process :)
You don't care about getting any air blown through the vents when your dash is back on?
The only things that made those boxes heavy where the cores inside of them wich can be removed. Unless you keep the blower motor and channel the moving air using duct?
Btw doing the fusebox wires must have sucked! I hate doing electrical work blah.
Discussion Starter · #17 ·
This wont be a daily driver so the last thing im worried aboout is having air being blown through any of my vents. Im having all the holes in the fire wall welded shut and i took those boxes out cuz i dont need them any more.. it will make room for all my extra goodies ill be hiding behind the dash such as: prop valve with brake lines, fuse box, and maybe even my battery(havent decided yet).......
and yes, soldering is a PAIN IN THE ASS.. I burnt myself a few times!
1 - 20 of 694 Posts
