1 - 11 of 11 Posts
well i have had my neuspeed springs for about 3 months now and now that ive looked at it, my springs are uneven. its lower on the right side than the left. its like a whole finger thickness different. wut can i do to fix this? the springs were used before, (but i got them cuz they were at a good price from my friends brother) is there anything i can do to even out the drop? and also, the ride is becoming a lot more bouncy meaning my shocks are blown. what are some good after market shocks that arent priced too much? kyb agx? koni reds? tokico?
lol i have the same problem with my coilovers...i had a big post on here a while ago about this..others have the same problem..i guess its normal..
not from side to side tho maybe you have one of the front springs on the back? With my coilovers i cant drop it as much as i want in the back because of the stock struts wont allow it i was thinking of bending that little hub thingy at the bottom but that dont sound to safe rite now so maybe i just changed my mind.But in your case i dont see one side would be lowwer unless the springs arent on the wheels.Oh yeah if you dont wanna spend too much money every here seems to like the agx
I have the same problem, just the front right corner is higher by about a finger, its wierd. Also when we put the car up on stands, the car was held up by only three corners, and the ground was level!!!
I think the car must have been in an accident or something
Might be a long shot, but check to see that your car isn't resting on the bump stops.
Also check that the spring is resting on the perch properly.
Discussion Starter #10
alright thanks you guys. what do u guys think about the KYB shocks sold at Kragens? i dunno.. im sorta low on money (student budget with no job) and there only 24 bucks a piece. my front 2 shocks are completely blown and the rears are about to. so do u think the 100 dollar investment for 4 shocks is worth it? wut about the quality of the shocks? and how long do they last on a 2.75-3 inch drop?
i got the full coil over system, it's not all that hard to get them the same height. just use a tape measure and measure from the top thread the desired height. and make sure it's even on left and right. that's how i did it and it came out just about perfect. maybe it felt easy because i went to do it at my friends shop and they got a lift also and it was way easier than jacking the car up and down 10,000 times.
1 - 11 of 11 Posts
