I installed Neuspeed Sport springs/KYB AGX shocks and had the perfect 1 finger gap at all 4 corners. After 2000 miles, both front wheel gaps are lower than the rear. The drivers front is 3/4" lower than the rear and the passenger front is 1/2" lower than the rear. I called Neuspeed and they told me this is a bumpstop issue. The springs are designed to drop F- 1.75" and R -1.5" which gave me the even drop when I first installed them but Neuspeed said that with the 1.75" drop in front, the car is actually resting on the bumpstops and since my car is 7 years old, they are probably worn out. So the solution is to install new bumpstops? My question is, are you supposed to ride on the bumpstops (uncut as instructions state)? I thought they were there as a protective cushion for when you hit a bump. Anyone know the answer to this?
