Based on what I have read here on the forum, it is a common problem for these engines to develop an oil leak where the distributor mounts to the head, apparently due to a seal going bad inside the distributor shaft.
Some people may be content with letting it leak and concentrating on other areas of the engine to repair or upgrade, thinking, “What’s it gonna hurt to have a little oil leak?” Well, I’m here to tell you if left unchecked, it will cause a lot of hurt - like replacing the distributor kind of hurt.
I don’t know how long mine has been leaking oil, but it was long enough for the oil to compromise the ICM’s wires’ insulation, causing it become brittle and fall away with the slightest handling.
I removed my distributor as part of a clutch replacement job, and the insulation crumbled and fell off in my hands as I unbolted the distributor and folded it back out of the way:
