no the type r will not fit the port sizes are bigger i had that problem when i did mine..... the manifold on a type R sits lower like the gsr's it will not fit on the ls i tryed it
you "MAY" have to get a new intake manifold
Are you talking about the IM or the TB, because the TB should fit (bolts) but the bore of it will likely be bigger than the LS IM's inlet bore.
im not sure what hes talking about but i still dont know whether the butterfly will secure to my stock ls throttle body if i bore it to 62mm.
or does anyone know where i can get a plate that is 62mm and will bolt in after boring?
