1 - 1 of 1 Posts
I recently swapped my dash, which I found out I had to swap all my SRS harnesses from OBD1 to OBD2 and I was wondering if anyone knew if that was the same case for the turning signals and horn? I've followed the harness coming from my steering wheel and found the plug. It is the typical small rectangle gray plug (very descriptive I know...) with all green wires coming from it. It is the male plug and I am wondering about the female plug, which is also gray and has all green wires that is usually found attached by a clip to the fuse box under the dash.
Basically I'm wondering if I just lost the female plug behind the dash or if there is actually a different connection between OBD1 and OBD2 turn signal/horn harnesses?
1 - 1 of 1 Posts
