hey bro, as far as i know the idle isn't supposed to rise on integras when using the ac or any other accessory. i believe one function of the iacv is to allow the car to idle properly with the ac on without the need to raise the rpm. if your iacv isnt functioning properly than you may have an rpm drop when using the ac or accessories that require more output from the alternator. most cars which raise rpm when engaging ac do not have an iacv. also, the emissions sticker on the bottom side of the hood would show a seperate idle speed for when ac is engaged. as a sidenote, i have a s300 unit and there are no options for raising the idle to a specific rpm when engaging ac. however, there are options to set the ac to cutoff at a designated tps output or desired rpm. neway, if your car is acting like its going to stall with ac engaged you either need to clean/replace iacv or check for vacuum leaks.
