once again it is all about what youre doing. one isnt better than the other. But for drag racing I would reccomend a turbo, since All Motor will require more money, more experience, and more tinkering to produce the same amount of power as a turbo set up. The trade off being turbo-lag, which is reduced with the right size turbo and ball bearing turbos (which are the sh*t, they really are), and probably motor life. Done right a turbo set up can last about as long as a N/A set up, but it all depends on how much restraint you have. Eventually you'll get the urge to add 5 PSI, just for one race, which is the one race which will put holes in youre pistons. So if you are looking for power to drag, my reccomendation would be a complete turbo kit from a reputable company, with a quick spinning turbo, an intercooler, and self restraint. A kit like this could run you anywhere from 2000-3500, and it could be worth paying more for ball bearing as the turbo will last longer, spool faster, and require less maintenence (you also dont have to worry about cooking oil in it). If you decide to run anywhere above the 7 PSI mark (which is pushing it a little on stock GS-R pistons) you'll want to build up you're bottom end with lower compression pistons, stronger rods, and if you go alot higher you may even want to look into reinforcing you're cylinder walls. This could run you anywhere from an additional 800 to 1500 dollars. You can also consider new cams, and upgrading youre valvetrain if you are planning on running high boost. Another avenue you have is a supercharger. Since you have a GS-R a JSRC (Jackson Racing Supercharger) could be a good way to go with you're higher compression. A scroll compressor type supercharger like that in the JRSC kit can provide a significant power boost all throughout the RPM range, is very reliable, doesnt suffer from any turbo lag, and limits you're ability to overboost you're engine since the only way to increase boost is by changing pullies, and you are limited by how much you can do with those. A JRSC will run you about 3000, and can be a good choice for drag, but is still very streetable and capable of Auto-X and other events easily.
As you can see there are alot of factors that go into choosing what you're going to do, and there arent any easy answers. Sorry for the novel, but I was trying to stay in the posting guidelines and not just spew useless rhetoric.
