Ok...I know it is ideal to have the drain on the turbo as vertical as possible...but...if it was almost parallel with the ground..but had an elbow on the end to direct the oil downward...would that cause major issues ?
Since the oil is coming into the turbo with force...would that be enough to also give it force out of the turbo ?
Thanks guys..i've been stuck on thinking about this.
*ScreaminTeg*
*ScreaminTeg*
